KD00LS said:When my car shifts into 5th, from easily accelleration, it makes a humming noise instantly, and stops the instant i let off the gas. Any ideas?
PHATCAT67 said:SOUNDS LIKE REAR END PINION BEARING GONE BAD, COMMON ON EARLY LS.
the early ls cars had the magical 3.31 rear.. great overdrive and top speed, but get em in 5th gear and lug em and you eat the preload on the pinions up, ( worked for a lm dealer and have seen it often...) hence in late o2 the cars started to come with a 3.58 like the ls v6 had all along... the v6 cars really had no problems with the ratio at all, and the v8s did so much better!!!! in fact on my 00 v8 base, i upgraded to 3.58 out of an 03 t bird, ( ls has an electrical brake, t brd had mechanical parking brake) and holy :q:q:q:q!!! wanna see power outta the hole? yikes!!! wishing now, that i never sold it for the 02.... gonna have to do it again!!!!!!! haha!!lsbit said:Where were you a month ago before I bought my car?
What was the cause of these bearings going bad?
eL eS said:I have the 00 LS6 Sport which did it come with? Or where can I check?
PHATCAT67 said:s/b the 3.58 in a sport, depends on manufacturing date too, check the sticker on the housing....
What don't you like about them?eL eS said:didnt like your magnaflow is that right? Reading the signature. I have mine as well. Wish I would have kept the stock system on stand by.
