Hydraulic fan actuator replacement one hour tops
Blueberryyum02
Griffen
Just changed mines out today, in truly less then 30 mins,
Drained resovouir
Removed tire
Got under car
t40 wit a short ext
Removed old one fish it out from the top
Connected new one drop it down in place screwed it in
Fluid did leak from it and on to the alternator
After it was snug I took a can of electrical cleaner and sprayed the heck out of the alternator.
The hour came in cause my oil pan was leaking tighten the bolts down no more leak.
I think the shop that did my alternator loosen up the four bolts on that side. Cause that was the only area leaking and the bolts was not snug at all.
Hi speed fan now works and I truly notice the difference in the air flow. You can feel it blowing like a house fan.
I would like to say thank you to the LVC community cause with out your knowledge and step by step instruction I would have not been able to do this. Thank you you all very much.
