bajaoutlaw
My 01 LS V8 w/ 54,000 had a distict miss, then CEL came on, steady. This began Monday evening, Went to Autozone, code said P 0301 Cyl 1 missfire. Bought the NEW valve cover gskt w/ the seals today, 4 plug boots just in case (all of my 5.4 tritons have burned through the boots @ 70K plus.
Anyway, all today ran better w/o doing anything, but not 100% and CEL is off. On the way home today on freeway decided to WOT, after slowing down CEL began flashing, ran rough, then after 2-3 minutes CEL went off and smoothed out. Pulled all the coils from pass. side, no oil, plugs look average. Put back together, no difference. The miss I had under load on Monday and Tuesday is now not a miss, just real bad power. Slight miss when in 5th gear under load.
I built both of the 540 CI 610 Dynoed Hp engines my boat, so I am not dumb, but I do not know what to buy next. 8 Coils, 8 injectors. Run a tank w/ Sea Foam, I give. Any suggestions before I ..... I ...... take it to a shop.....
Stop the madness & help a brother out.
