fratzke7
I have replaced both lower spindles both upper control arms both front sway bar links and the thing still effing clunks!!!!!! What next? I have so much money in this damn thing that I will never be able to sell it!
sway bar bushings, engine mounts, transmission mounts... all things to look at for "clunking"
also a possibility, but much less likely... control arm bushings...
Someone on here replaced the factory rubber bushings that went out (usually there's a sqeak, but if they are bad enough it could be a clunk) with Energy Suspension poly bushings.
I see big rims - are you lowered as well?
That was my though as well. Big (heavy) wheels and suspension problems..... hummmm
