Ok, so my wife's 2000LS (3.9L) was having the overheat at idle problem which a lot of cars seem to be having. I just finished replacing the Hydraulic Fan actuator and thermostat to fix the problem. While I was at it, I decided to replace the thermostat housing with a Jag aluminum piece. In a rush to get the car back together before nightfall, I somehow swapped a coolant line with a vacuum line. :slam I even remember asking myself why a vacuum line had a hose clamp, but never put two and two together.
You can see the two lines circled below (random picture on the internet, not my engine bay):
Of course, I didn't realize there was a problem until the engine started and (once the engine heated up and thermostat opened, presumably) I saw white smoke and a small stream of water/anti-freeze coming out of my muffler and white smoke out of my tailpipes. I immediately shut her down and was going nuts trying to figure out how I managed to blow a head gasket (I was still convinced that I couldn't have misplaced any lines). No anti-freeze in the oil.
I decided to sleep on it and the next day I came out to check everything again and immediately saw my mistake. I swapped the lines, refilled the coolant, and she started right up and runs great - no engine damage that I can see. I've run the car up to operating temperature (I think the overheat issue is fixed), but haven't moved it. No codes.
At this point, I think I dodged a huge bullet - but I want to make sure I don't steal defeat from the jaws of victory here. Question: what does the lower geometry on the 3.9 intake look like? Is there a large lower plenum area where coolant could collect? My #1 fear here is that coolant collected somewhere and I frag the engine taking a turn or something. Do I need to remove my intake? Any other ideas on critical things to check before calling it good to go?
