I got a 94 TC with 135K. The engine has a rough idle, it shakes a little bit, enough to feel it inside the car. Sometimes when it's idling, the rpms will drop to the point where it almost stalls, then the rpms will pick up again. I already replaced the IAC, cleaned the egr, changed the plugs, cleaned the MAF, cleaned the EVR filter, and replaced the fuel filter. I scanned for codes and got code 136 (exhaust bank 2 is lean). Already replaced 02 sensor in bank 2. Anybody know what else could possibly cause this, I'm running out of ideas and out of money. :slam
