Well, the engine will not start. The engine cranks. Coil packs are new. Fuel pump works. Lights work. The ignition control module is the last thing, but I do not know where to look.
Just an update, apparently the problem is a faulty ECM. From what I understand is that the TC has had issues from '96 on up or so with the ECM. A lincoln dealer said that if it hasn't gone out yet it will.
