Replaced the key switch lever, more later, now it turns over but will not fire. Going back out to try the neutral interlock cable on the top of the steering assembly. Maybe I put it back wrong? All else seems fine, cranks like crazy, steering wheel lines up, key in same old spot. Found, what I believe is the original old pin, mechanic replaced the lever the first time, on the floor, after putting everything back together. Any help appreciated. Thanks, Ed
