Forgive the remedial question, but this is the first car I've worked on or modded since a 1974 Pinto about 25 years ago. I don't really understand how modern cars with an ECU/PCM work. My understanding is that it will adjust the fuel-air ratio and ignition to adapt and that increased airflow through the system will provide a minor boost in HP, assuming that the PCM adjusts other settings to compensate.
I've installed a K&N filter and vented my airbox by adding a 1 1/4" hole to the bottom. After resetting the PCM and letting it relearn, it's running smoothly. I did not bother with a dyno before or after and I can't tell any difference in power, but the exhaust note is a little throatier and I like it.
I'm thinking about increasing the airflow more by adding another vent hole to the airbox. My question is, how far can I go with the stock PCM before it can no longer adjust? Is there a limit where if I go past that, I would need to get an XCal and retune?
I've been reluctant to buy an XCal for two reasons: we do not have 93 octane available in San Diego so real performance improvements seem unlikely (the stock tune is for 91 octane) and I'm concerned that flashing the tune will leave a "fingerprint" (like a timestamp or something) that would give service an excuse to void my warranty.
What say you about these things?
