info on dohc
That engine is not part of the modular family.
Lincolns Own said:
they forgot the 5.8 351 that was in the ford broncos. dunno if those were DOHC or not.
good info indeed. Perhpas a re-post of this under a "performance" forum? Something that would make it easier to find when you are looking like info on the fly?
I found out recently the 93-95 Mark VIII rods are the same as the 2V rods and only the 96-98 Mark VIII's got the Cobra rods.
The Sho V8 is a 3.4 DOHC, the 3.9 DOHC was introduced in the Lincoln LS in 1999 or 2000 I think. It got variable valve timing a couple years later.
Same pistons as the 2V as well. Cobra had unique internals.
For your information the Cobra R model used motor mounts that lowered the engine in the chassis 12mm, It did however, bolt onto the standard Mustang cross member. Something to think about if you are having hood clearance issues.
Might be useful information for the people that have installed a cobra intake in thier Gen1, and can't close the hood.
