I finally found the proper Torx bit to install the LMS/C&L housing so I did it today in the morning. I had already put on the 9 inch K&N conical about a week ago. At first, the car was idling rough but after running it for awhile and going around the block a couple times it has smoothed out a bit. Hopefully the rough idle will go away completely after 2 full drive cycles. I can't really tell if it made a difference but we'll see at the track. I also have this CEL light that comes on and off from time to time. It's code 189, system adapative at limit at partial throttle/system lean. I actually got this code first in the morning before I installed MAF housing. Any idea why it's coming on and then turning off and not staying on the whole time? If it's just popping up randomly and disappearing is it just a dummy light?
