iPhone 4
n8bachelor
Bentonville, AR
Anyone get one? If so did you have trouble with dropped calls?
I have read that the exterior antenna is a crappy design. Of course apple just says "you're holding it wrong" and "it could happen to any phone". I just want to know how bad it really is.
If the iPhone 4 came to Verizon I would probably get one.
I love mine I've had no problems and I've tried to hinder the antenna. I've had the previous versions as well and I'd rather cut off my arm than get any other phone. That's just my 2 cents.
I have one. The antenna issues is definately an issue. However, it only affects me if I hold the phone, with no case, and my hands are a little moist.
However, once you put the phone in a case of some sort, the problem goes away. You want the phone in a case anyway to help protect it, so really, it isnt much of an issue. I bought a $25 case and all is well.
The display is awsome! Its basically high def, which is great for photos, etc.
My fiance has one and she has had issue with it dropping calls randomly and then coming up and saying no sim installed. FYI if you press the top button and then the home button it does a screen shot and saves it to the gallery.
