Joined 5speed clan
Kingbenny05
US
Need help on how to bleed a V6. Think that's what it needs. No heat. Coolant full, no leaks. No hot air, not cold, cold thou. Told to bleed it. Then check thermostat. I can't find bleeder valve. Any help is greatly appropriated.
Sent from my SM-G360P using Tapatalk
Well, if the coolant hasn't be drained/filled and you need to bleed it, then you have degraded plastic that is letting air in somewhere. If you bleed it and it is then okay for one or two trips (but then the problem returns), then you know you need to replace the plastic parts.
Bleeding for gen I LS (V6 and V8): http://www.lincolnvscadillac.com/tech/drain-lincoln-ls-cooling-system/
