June Specials, New Products & FREE Chemical Guys E-Zyme Natura Wax ($275) Give-Away
Detailed Image
Albany
June '09 Monthly Specials
Gilmour Foammaster II Foam Gun
For the month of June we put the popular Gilmour Foammaster II Foam Gun on sale. Normally $59.99, on sale for $44.99! The Gilmour foam gun is perfect for pre-soaking your vehicle prior to washing to allow the shampoo to start breaking up dirt and contamination without the need for you to touch your vehicle. By breaking down the contaminants before washing you will do less scrubbing which minimizes the possibility of adding ultra fine imperfection the paint while washing. Using the foam gun also allows you to coat hard to reach areas with shampoo offering a more thorough cleaning. Just pour a couple ounces of your favorite shampoo in the reservoir and start spraying foam all over your vehicle. If you are looking to add a little more fun to your washing process while reducing the chances of adding imperfections, the Gilmour Foammaster II Foam Gun is for you. We recommend pairing the Gilmour foam gun with one of the Chemical Guys shampoos for maximum suds and dwell time.
Ultra Plush Microfiber Towel
Stock up on one of our best selling towels, the Ultra Plush Microfiber Towel. Normally $5.99, on sale for $3.99!This two sided towel has one side with very thick nap, perfect for quick detailers, final wipe downs and interior dusting, while the flip side has a medium sized nap ideal for product removal from polishes, sealants and waxes. Keep one of these towels handy in your glove box along with a quick detailer for quick removal of bird droppings, dust, pollen, sap, etc. The microfiber edging and tagless design makes this the perfect paint safe towel.
New Products @ Detailed Image
We've added a few new products over at Detailed Image...
Two new gallon sizes of some of our most popular Chemical Guys products: CG Synthetic Quick Detailer 128 oz and CG Grime Reaper 128 oz
Four new Dodo Juice products:
Dodo Juice Born Slippy Clay Lube Concentrate is one of the best clay bar lubricants I've used to date. Don't let the small bottle fool you, the recommended dilution ratio is 10:1 which makes over 2.5L of product. Even at such a high dilution this will be one of the slickest and most effective clay bar lubricants you will every try. Wipes away streak free on any surface and makes claying easy.
Dodo Juice Sour Power gloss enhancing shampoo is a perfect maintenance shampoo designed to maintain your coats of protection while leaving behind and added layer of gloss. The highly concentrated shampoo has lots of lubricity and a little goes a long way. The addicting scent will make you want to wash your car more frequently than normal.
Dodo Juice Tropical Red Mist is a gloss enhancing quick detailer perfect to use after maintenance washes to extend durability of any sealant or wax while restoring tight water beading to your paint. Red Mist is easy to apply and remove streak free with one of our Ultra Plush Microfiber Towels.
Dodo Juice Time to Dry is unique product that is designed to aid in drying your vehicle faster with less chances of adding imperfections or water spots to your paint. Simply mist Time to Dry on your wet paint and watch as the water begins to break up before you even begin to put a towel to your paint. The added lubricity will help minimize adding imperfections and make your drying process more efficient.
Menzerna Power Finish 16oz now available. This is Menzerna's most popular polish as it has a cut level similar to Super Intensive Polish and finishes down close to PO106FA.
Optimum Finish polish is another polish added to the outstanding Optimum line of products. This is OPT's finest polish and works wonders on removing holograms, light hazing, and other minor imperfections while enhancing the gloss and depth to a high level of shine.
Chemical Guys E-Zyme Natura Contest $275 Value
Here's your chance to win a jar of our most expensive wax, Chemical Guys E-Zyme. Give your vehicle outstanding protection along with deep, wet, sharp reflections, making your vehicle stand out from the rest.
View our simple entry steps on the Detailed Image contest page for your free entry into the drawing.
As always, if anyone needs a hand selecting any products or has any questions on anything, please do not hesitate to ask.
Thanks for reading!
Greg @ Detailed Image
Good luck. This is the best wax we have ever carried at Detailed Image I know you'll love it if you win it. Thanks for entering.
This is your last chance to save on the Foamaster II Foam Gun (Save 25%) and the DI Ultra Plush Microfiber Towels (Save 33%). The sale ends on 6/30 at midnight EST. Also don't forget to sign up to win the E-zyme Natura Paste Wax (retail $275). Entering is totally free and open to all!
