So I've been needing to do replace a few of my coils after ive been noticing them breaking down. so i decided to purchase some coil packs for a 4.6 mod motor through GMS, knowing that the wiring harness would connect (tested it on my friends 04 GT)i knew it was possible. So after i recived them i unplged mine to notice the stainless wires arn't long enough, but luckly they are adjustable just enough to snap on the spark plug. but my next problem was the bolt holes dont line up so i threw some good size washers onto the bolt and bolted them down, and i repated the process for the other 7. After i was complete i cranked it over and sure enough it fired right up. The car idles so much smoother and i can notice a huge difference in the mid range power, and my gas millege went from right around 15 to just over 17. I figured there might be a few more people that where curious if the 60,000 volt coils from GMS would work, so i figured i would be a test dummy on this one, and so far so good.
		 Part # please..
 Part # please..
