03LS-sport
Hey everyone it's been a long time since I have been on here. In the year that I have owned my 03 LS sport and it has given me more grief and problems then every other vehicle I have owned combined. Here is a list of issues I've had and some that I have solved (for now at least).
-the notorious coil packs. Spent a while finally getting the bugs out of them. Had to eventually switch to excel coils that I managed to connect to the stock bolt holes. I've had a few issues with moisture getting to them but a good coating of dielectric grease has helped.
-had to replace the cats because they were shot due to bad coils dumping fuel into the exhaust. Those weren't cheap because I was living in communist California at the time
-when I gun it to get onto the freeway or just have fun the car will sometimes sputter at first then the whole car starts to smell like un burnt fuel. This one is confusing because even if the windows are down it smells stronger then my '79 f150 did with no cats. The smell goes away after about 5 minutes.
-when cruising down the freeway at over 70 the whole car starts to shake. I have had the tires balanced and rotated and it didn't help at all.
-fuel pump is going out I think. Sometimes the car just won't start and when it starts it sputters and putters and sometimes dies. Then decides to run great for a while. But will then just go back to sputtering really bad at idle. (I don't think it's the coils because no codes pop and it seems to run fine once I start moving)
-the transmission is having issues. The hard shifts from 2-3 and then sometimes when it goes to shift into other gears it's like the transmission forgets what it's doing and pauses then goes into gear.
-the driver door handle doesn't like to work from the outside. It's about 50/50 chance you will get it to open without having to reach in from the passenger side and open it.
-when I start or turn off the car the steering wheel jerks and sometimes just stops moving when it tries to go to the pre set position.
-the clock spring is starting to go out so I sometimes lose steering wheel button controls
Is anyone else having as many issues as I am?!?!
I have always wanted one of these cars since they came out and it's a great looking car and it has a good sounding magna-flow exhaust so I enjoy the V8 sound. So far the interior stuff hasn't given me issues and I like all the features. But I just do not trust this car. Every day I drive it I am expecting something else to stop working or fail. I don't let my wife drive it unless she is just going 2 miles into town because I'm afraid it leave her stranded. I am a die hard Ford fan and lincoln fan but this car is poorly designed. When everything works it's awesome! But then the problems come back and I hate it. I highly doubt I'll have this car much longer because I want something I can just enjoy instead of stress out about.
