Hi all,
So i purchased myself my dream car / first car a 2002 lincoln ls v6. mint inside and out ... i will post pictures later i think it has newer ls rims on it not sure but will see later
only one owner, and i purchased it from a used car lot dealer off the street.
only 93k miles ..
so far all i have done was new breaks , rotors & bank2 sensor 1 o2 sensor.
anyways now i have engine light on for egr valve clogged (code p0405) this happen after i used zmax oil and fuel cleaner... what can i do to fix this? how much would it cost if i bring it to a mechanic ..
and every now and then only happen about four times the abs and traction light or is it the advance track light comes on once i turn car off for a while then back on it goes off but i know it will keep happening..
i also notice the cars horn works but sometimes and only when the wheel is straight. the knob to adjust the steering wheel still works. other than all this the airbag light doesnt work so i hear the 5 beeps the car makes which i looked online and pretty much found out why its doing that.
thanks a lot and you guys will see me around here more often i love forums
p.s i also forgot to mention the car leaked anti-freeze the first like 4 days i had it on and off. what could of caused it? could it of had been it was over filled? or a lose screw?? like a freeze out screw? it stopped leaking
wen the car is on is the anti freeze suppose to go down and when its off it goes back to normal level?
only 93k miles ..
