K&N Intake Brackets
JohnDoss01
Illinois
I need help from anyone who has the K&N Typhoon intake!
I recently scored a used typhoon intake, and am currently installing it, however I discovered that I do not have any sort of bracketry to mount the heat shield.
If anyone has pictures of their heat shield and how it is mounted, that would be helpful! I can make brackets, I'm just having a hard time visualizing it
You should be able to find some pics on this forum of the Typhoon. I ran across threads with pics of the Typhoon a long time ago when i first got my LS. I dont own a Typhoon but from all the pics i have ever seen theres a single bolt hole in the bottom. Before you make brackets you can try Home Depot or Lowes or any Hardware store in you're area and you might find something that you can make work. Good Luck!
