Ken and others, what is the best wood dash kit out there for the 05 LS? HELP!
2006kmls
New York City
I see there are no "molded" kits available? Is this true? When you call them they tell you the "flat" kit will look great and not to worry about it?
What is the scoop?
I can see areas where the "flat" kit will work and other areas where it will not?
When they refer to the kit as "flat" is it 100% "FLAT"? It clear to see that some of the areas need to edges to conform to the detail of the dash or the plastic under the wood trim will show through? Is this true?
I really just want to do the center console from the a/c vents all the way down to the shifter area.
What is the best kit and way to do this. Also, can you sell me the "LINCOLN" letters or provide the part number, I'd like to add that detail to my dash.
No one makes a molded dash kit for the LS's existing wood on the doors and the strip across the front of the dash. I took my door panels off, removed the wood pieces and covered them with the carbon fiber vinyl. I did the same thing with the pieces between the steering column and above the glove box.
There has been a couple of LvC members that have painted theirs. It looked really good.
