Key/Door chimes
mcford
Portland
where in the heck is the danged "dinger" that sounds when the keys are in the ignition and you have the door open. it drives me INSANE and want to rip it out.
Mike
just listen to the dinging. it will get you close. its about a 1 by 2 inch box and was under the dash in the middle of the car in both my dads '97 250 diesel and my brothers '92 SHO.
yep. did dsome digging for this on lincolns online too. between the few different posts, i found the lighting control module. pulled it out, took it apart and found the "dinger". quick twist of it with a pair of slip joint pliers and the dining was all over. Put it back together and all is well. Thanks man!
