Keyless Entry
JRMARK8
wixom/bx,nyc
My Keyless Entry Doesn't Work And The Same For The Light On Driver Side Door Panel What's The Deal.
ANYBODY? THIS HAPPANS 50% PERCENT OF THE TIME
I had that problem a couple of months ago... your best bet is to get a new transmitter, and program it yourself... its not hard whatsoever. But the light... did you check a bulb or anything like that?
You have to be a bit more speciffic about the problem. Do the keypad lights light up?
Can you lock the doors with the 7/8 9/0 buttons?
Did you check the fuse?
As far as your door is concerned....
I CHECKED THE BULB AND REPLACED,THE FUSE LOOKS O.K., AND THE DOOR SWITCH IS WORKING;BUT LIKE I SAID THERE ARE DAYS THAT IT WORKS AND OTHER DAYS IT DOESN'T.
If the door light works intermittently, then I would deffinitely check the switch when the light is not working.
Incidentally, what procedure did you use to check the switch?
did you just whip that up?
