'88 Mark VII, 6-way power seats
Anyone know what the seat cushion switch does? It's a long, flat metal strip with 2 wires coming off it, and a connector. It's mounted crosswise under the seat cushion. Pressure on the seat causes continuity between it's two wires.
The reason I ask is my driver lumbar support never worked (for me anyway). It turns out that a prior owner had mistakenly plugged the lumbar compressor into this "keyless seat switch". (The electrical diagram sheets call it that.)
None of the wires involved had power, nor were they grounded so nothing bad happened..
This mis-connection is easy to make while sorting things out under the seat. The proper lumbar-switch connection is hidden away in a dark corner, while the seat-switch connector hangs in plain view. Both use an identical grey 2-wire male/female.
The electrical diagrams show a direct connection from that seat switch to the 2 under-seat courtesy lights.
I've been running the car for years and, afaik, everything works properly.. underseat courtesy lights, seatbelt warning chime, and everything else..
I'd rather not hook up the seat switch without knowing what it does. My general philosophy is to leave well enough alone. If someone knows what it does, i'd appreciate it. The shop manual does not seem to even mention it in the seats sections (Volume B, Group 41)
btw.. the reason I got into this in the first place was my driver's seat-back was loose all of a sudden. One day last week, the back could easily be bent backwards a couple inches.. springy.. soft... and lopsided.
I unzipped the back-cover and pulled it up and saw that the sheet metal frame had cracked. It looks like a couple spot welds failed long ago, and eventually things gave way, tearing the metal... a nice, straight, horizontal 5 inch tear about 8 inches up from the hinge pivot on the left side. At first glance the crack looked like it was factory.
I welded it back up with no problem..
I had to remove the lumbar-compressor before welding since it's mounted in close proximity, and decided to fix the lumbar support... and give the whole seat some deferred maintenance...
