94silvermark
Hello everyone last weekend i bought a nice 1994 mark viii that has a few issues. The engine is running pretty rough at all rpms but smoother at higher rpm. I went and pulled the codes today, it flashed code 225 for knock sensors failing to be found with the engine running. I performed the koeo and koer test. I'm still waiting for my factory service manual to come in the mail so the procedure i used was from the manual i have left over from my 1990 ranger that also had an eec-iv pcm. I was reading on here about other tests that i am not sure how to execute, someone was talking about a goose test and a cylinder balance test. If someone could tell me what those are that would be great. Any input on other common causes of an engine condition such as this would be wonderful. I saw that the gen 1 cars had common idle air control valve failures so that's another possibility. The computer calculated mileage at 9.4mpg so this needs to be fixed soon.
