L.S.D. swap
The rear end in our cars is a Jaguar piece and it is not the same or compatible with what you linked to.
quik,
could this work. I didn't think the LSE had a limited slip rear diff. Maybe the Auborne might fit into the 8". Whoo Hooo if it does:D
-dom
hockey930 said:
just take one from a sport if you are just looking for an lsd?
Eamonn
as far as I know - there is no difference in LS models other than gearing between some years. all LSes have an open diff.
dmgraz said:
quik,
-dom
may be - I am no expert on diffs. Will the case fit inside the housing?
Sounds like someone needs to try it!! :hint hint:
supposidly, the jaguar s-type (perhaps the v8 or the R) has a 8" Limited Slip Diff in the rear. ;) Thats going to cost a pretty penny to buy.
