LED Headlights
05-LS
Hobart
I recently installed OPT 7 H11 low beam led headlights. The effects I'm sure are blinding to on coming drivers. Is there a way to correct this?
no way to correct it plain and simple. with standard headlights the fulfillment is in a very exact spot and all of the reflectors are aimed based on that very specific spot, with HIDs or LEDs the source of light is in a slightly different spot, and some of those reflectors are going to scatter light in the wrong direction. with LED bulbs, this is even worse since there are many different sources of light causing even more unintentional random scattering of light.
