D
Deleted member 22631
Guest
I have a 2001 Lincoln ls I just purchased a led bulb to replace the factory trunk bulb, it works perfect but when the trunk is closed the bulb emits a low dim light that hasn't gone out. Is this an issue to be concerned with as far as battery drain, fire, or electrical, I have read that these leds use such a low amount of electricity that it is possible the car isn't powering down low enough to shut it completely off and it is running very low on the low current the car continues to give due to the computer etc.... is this true, just wondering if anyone has replaced theirs with an led bulb to factory plug or if anyone has found a solution to this after glow
