Left front abs sensor
I believe you can just pull back the fender liner and follow the cable. Looking at the length of the new one should give you an idea about where it will plug into its connector. If you're talking about the sensor itself, it is a black thing mounted behind the wheel hub and is held in by one bolt. Which will be possibly be frozen. If you get the bolt out then the sensor will likely be stuck in the mounting hole. Since you are replacing it anyway, you can beat it out without having to worry that you broke it.
Abs
My left front sensor got coated from over greasing the front end. The bearings were bad and heated and cooked the grease. Cleaners wouldn't clean it. I scraped it off with a razor blade to un-cover the 4 metal strips and it measured the same as a new one with a meter. I did change the hubs and sensors. If the sprockets are all black this could be your problem.
No I know it's the sensor. I broke it off by accident. I knew not to try and remove it I should have listened to myself. Stupid mistake
