Lincoln LS 3.9L V8 Engine Parts
Thomas A
Overland Park, KS
These parts were removed from a 2000 Lincoln LS with about 20,000 miles on it. The motor developed a knock and was replaced. The issue found when the motor was torn down was a bad rod, but it was not enough to damage other items. I am listing this for a friend, so please contact him directly through email: gogo50_88 AT msn DOT com
He is open to reasonable offers. Parts are located in Omaha, NE if you happen to be local and would like to avoid shipping. I will personally vouch for him; he is a good and fair guy to deal with. All prices DO NOT include shipping costs.
PICTURES --> http://www.adenracing.com/Pictures/LS%20Parts/
Front Timing Cover $75
Intake Manifold/Fuel Rail & Injectors $100
RH Intake/Exhaust Cams $50
LH Intake/Exhaust Cams $50
Valve Cover/Oil Fill $25
Power Steering Pumps $100 each
Throttle Body/Adapter with Sensors $85
Starter & Harness $75
Engine Bracket/Mount $45
Exhaust Manifolds $75 each
Oil Pan with Filter Adapter $75
Harmonic Balancer $65
Heads complete with Valves/Cams $150 each
The engine was complete, so if you are looking for something else motor related that is not listed, let him know. He only had the engine, so there are not any other parts from the car available. Thanks for looking!
TTT
Pictures should be back up tomorrow. I forgot to pay my bill. :p
Anyone need any of this stuff? He is open to offers, esp. if you happen to be local. I live a little west of Kansas City, and can help transport any of the larger items from Omaha to here if needed.
Thomas
Interested in the cams for research purposes. Would like to know the stock lift/duration. Whats the lowest he'd take for either a pair I/E, or the set of four, I highly doubt anyone else is going to be interested.
i would be interested in the exhaust manifolds for the right price. I only really need them to cut up so it would have to be kinda cheap. So you guys are in omaha. Do you know if we have a local Lincoln club? Would you guys be interested if not? If he hasnt sold those exhaust manifolds yet i would offer 75 for both(75 for two, not 75 each), if not i would consider buying 1 for 50 and i would just draw up the pattern and laser cut the second one(i just need the pattern).
Sent you a PM....
I'm not aware of a Lincoln Automotive Group in Omaha. There is one in the Kansas City area, but that might be as close as you get.
Thomas
Any chance you have the air filter housing and the piping after the throttle body?
Nope, just the actual motor parts themselves. That would of stayed with the car when the motor was replaced.
Thomas
