DaleGrib
I tried to use a few different tools to bleed my ABS system and it fails to do so. I also tried with forscan with the same result. I am not having any braking issues with the car but I have seen time to time in the codes that ABS module had invalid data/ and or bad PCM but I checked the codes with Motorcraft website they match. So does anyone think this could be the sign of a failing ABS module? I have cleared that code and it has stayed away for quite some time but I know the car should do the ABS bleed as I have done it on other LS's in the past. I was thinking of grabbing a used ABS module of eBay and programming it with ForScan and give it another shot. I just changed my rear calipers and all the cars rotors and brake pads and none of that helped. I kinda didn't figure it would help bleed the abs module but it was not something I could rule out because I suspect these rear calipers had been failing since I purchased the car. I grabbed a used PCM on ebay for $20 in case and being that parts is getting harder to find for these older Ls's I figured having a spare PCM is not a bad idea since it only cost $20. I know ForScan won't do the PCM programming but I have a copy of Ford IDS and I plan to get a good cloned VCM soon for things like that. I would rather spend the $150 on a good cloned VCM vs paying the dealer $150 to flash the PCM.
