Lincoln wheels on Nissan Maxima???? Spacing??
dirtbikekid
Texas
Will my custom wheels from my Lincoln LS fit 04' Nissan maxima, both are 5 lugs but bolt pattern may differ, thanks!
If the bolt pattern is different, then you're SOL. If it is the same, then you'll need to know the backspacing of the nissan and your LS, as well as the tire size. Then, and only then, you may proceed to 1010tire.com, and play with their backspacing calculator, which will tell you if they would fit.
your not sol if the lug pattern is different just search for a spacer that will change your lug pattern. just do a search on it and you will come up with the results. my friend did it when he traded in his rodeo for an expedition. hope that helps
