liquid on carpet
SAINTLUEY
MiAmi
got a 99 tc. now on the passenger side it seems like each time i put on the ac the carpet gets wet. I pulled off the carpet and only saw these two holes with plugs on em. so i silicone em thinking the water was coming from undeer the car ( puddles) but this didnt work so now i am pretty sure it is coming from the ac but i see no pipes or anything. anyone experianced this and know where i could locate the problem and fix it?
Using your a/c produces water.Usually it'll show up on the ground under the car. It would appear that your's is leaking out of the dash onto your carpet.Look for the tube coming out of your firewall that drains the condensation and make sure it's not plugged up or something.It may also be coming from a crack or a seam in the box that holds the a/c components.If you can find where it's dripping out you may be able to seal it.
