I have a loud humming noise from my rear axle. The noise is consistant whether I am speeding up or slowing down which leads me to think it might be something other than the diff. Has anyone experienced this?? Thank you very much.
docsayler said:I have a loud humming noise from my rear axle. The noise is consistant whether I am speeding up or slowing down which leads me to think it might be something other than the diff. Has anyone experienced this?? Thank you very much.![]()
mharrison said:I have a bad rear wheel bearing. Mine starts about 40mph and increases in pitch. If yours is constant you may be able to do do-nuts in a parking lot each direction. Since mine starts that high, I tested mine on an empty, straight stretch of interstate. At 60mph I jerked it to the left (quick, but not far) straightened out, then jerked it to the right....kind of a long shallow curve. This loaded up the different wheel bearings. One way it quit making noise, and the other way it was loud. When you turn left it loads up the weight on the right rear, turn right it loads up weight on the left rear. So the one that makes the humming noise while loaded up, is bad.
