MatthewDavid
So I'm still getting a low coolant air... I know it's not low cause its been filled... and I doubt there's air unless there's a way for air to get in there from a difference in outside temp... cause I had a couple bubbles and I worked them out... anyways I think it's the sensor... could be wrong but it just goes off a lot... like 2 or three times a day and it's full... with the air in the system it would only go off once a day... anyways how hard is it to change the sensor and how much do they normally run. thanks!
