Dern Humpus
Everytime I start the car I get a Low Washer fluid message, and then I hit reset to clear it. I have been adding fluid and filling it up but the message doesnt stop appearing on startup. What gives?
Yea, anytime you're dealing with a sensor, its a good idea to check the wires, plugs and electrical contacts first.Corrosion is your #1 enemy when it comes to electrical connections.I always put a little electrcal grease on my plugs before I plug them back in.Bmetzger8 said:It seems like everytime something happens to my car, the majority of the time its a poor connection/bad sensor.
-Just about every year I get the door ajar message even when all my doors are shut. I just spray a little WD-40 on the contacts and that takes care of it. Maybe there is a similar fix with the washer fluid problem?
