tons lower, really makes the car look 100x better, gets rid of that 4x4 look with aftermarket wheels
I just never understood the point of lowering.
IMHO these cars are already lower than most. What would be the point of lowering it more?
It would be nice to get a jack under it if you have to change a tire never mind speed bumps and pot holes.
A. Search, tons of people have lowered and there's a lot of info on here about it.
B. I wouldn't do it if I could go back and have my choice again. Besides appearance and MAYBE a slight handling difference it's frustrating not being able to go to a few of my buddies places because the complex they live in is speed bump riddled. Or the gym. Any yes, I'm well aware of the one wheel trick. Doesn't work when the speed bump is 4" off the ground. Or when you look down leaving the gas station and for some reason it has a super steep decline ramp leaving and cringe slowly inching over it.
Just my .02
Been wanting to lower my LS too. Also wanted to put some spacers to have the tires stick out more for a aggressive look. I just don't know where to start or what to look for.
the lower center of gravity gives the driver significantly more control of the vehicle and reduces flex by a lot...
i was talking about lowering any vehicle in general bc the question/conversation wasnt exactly ls specific. you removed that from the rest of the context of the post, which wasnt fully enveloped in 'LS only'. i was generally talking abt the extremes of a lowered truck vs. a raised truck <or a truck that sits high stock> when i made that comment, which is fundamentally correct <maybe spare some sort of scientific terminology which 99.9% of readers here are not going to fully understand anyways (self included) >. ive never lowered an ls, nor would i, for <basically> the reason you mention: theres limited improvement capability in performance and 'looks'... and it comes at the expense of untold $$ and lots of time/work to do it right so it aint worth it IMO.There's a lot of wishful thinking about that statement, with nothing from a physics/engineering direction to support it, as applied to the Lincoln LS. The generality 'flex' requires the question, "What flex are you referring to?" There's no height above the pavement component in an examination of chassis deflection ('flex'), for example.
If you're talking about the difference between an LS driving down the highway with 18 inches between the pavement and the rocker panels as opposed to a stock height LS situation, your comment may have some merit. But a stock-height LS at highway speed is unlikely to have significantly less handling than one that's been lowered an inch.
At significantly higher speeds, lowering by some small amount ONLY IN THE FRONT will help with airflow under the car. The belly-pan on my '02 LS Sport/ ECTA land speed record holder---E/F CC class---provides me with rock-steady handling at speeds over 150 MPH. And I have stock height springs on my car.
Somewhere up above in this thread is a statement that ideally for handling, the car should be 3/4ths of an inch lower. But doing it properly takes enough effort that the only justification is really just for the looks of it, not from any objective 'handling' basis.
KS
Just my .02
Just my .02
