So I've reached an impasse on this problem. First thing I do is the DATC checks and find only one code either continuous or on demand. That was 2426 which from research is the solar sensor. Huh?
Check the compressor clutch to ensure it is engaged. It kicks on and off from the interior controls just like it should. It doesn't sound bad or squeL or squeak. Huh?
Use a service hose to check my low pressure and it reads 55 psi. A little high but definitely not low on r134a and I believe rules out a leak. Huh?
The car isn't blowing full heat it's more lke the vent is going so it will blow air the same temp as the engine compartment or outside. The air blowing out is the same temp on both sides of the cabin. Huh?
So now I'm scratching my head. I don't have service gauges to check the high side but I'm not crazy to rush out and buy them if I can avoid it. Ideas? Is the compressor faulty internally? Is it DCCV even though it's not blowing full heat or uneven across the cabin? Could I have a blockage in the line? I'd like some input on how to proceed please.
