March 10-12. Convention center next to the Dome downtown St Louis. To late to enter. You have to fill out an application and send in pictures. i applied two months ago. The organizers then determine if your car should or should not be in the show. $50 entry fee.itsnotmydaddys said:NICE, when is that car show. when do u have to enter. also how much is it to enter.
I think it is $13 to get in. I plan to be there friday from 3pm till probably 7pm. Saturday from 11am till 4pm. Sunday most of the day.itsnotmydaddys said:how much just to go to the show. when will u be there. im planning on going to check out the cars.
:IohioLS said:Take some spray tire shine and spray all your wheel wells. Good Luck!
DITTO!!! you might even want to spray the exposed portions of the tires.ohioLS said:Not to be rude Rollin LS but I would take some spray tire shine and spray all your wheel wells it will give you a wet look and will hide all the dirt. Just from past experience is all. Good Luck!
-Scott-
itsnotmydaddys said:the lincoln star
I just found a place in town that will make me heat treated color matching paint in a spray can to do my calipers. I plan to do the calipers the same day I swap out the new drilled and slotted rotors. I hope to have them done in the next few weeks.dsoul27 said:I love that car..... are u gonna paint your calipers? I would go the same color as the body...
man.. about how much money do u have in that thing?
Chrome vinyl. I sat on the floor to take the picture. The plenum reflected light onto the decal for the picture.RED LSV8 IN MA said:Thanks!!
I meant what is it made of, painted on, etc...
It fit fine without cutting it out.RED LSV8 IN MA said:The Razzi kit says you have to cut the front grill out of the factory bumper to make it fit. I see that you did not, how did you make it work.
Also what is that on the underside of your hood.
Won my class, Conservative Hardtop 1990-2003.PM80 said:So how did the show turn out?
