LS beeping at me when I start it
free139stylz
Maryland
Hey I have posted this on here before and didnt get a answere I also took it to 2 dealer ships and no one can figure out whats wrong. everytime I start my car is beeps like this beep beep beep beep..... its beeps for times pauses and beeps for times again. it does this 4 times and then will stop. no message appear anywhere while it does this. The beep noise is the same noise the car makes if you hit the traction control button. And if im driving for like an hour straight it will start beeping again while im driving. If no one knows how to fix it atleast tell me when the speaker is that makes this good awful beeping noise so i can remove it./
What year is your car? Are you sure it's not the seatbelt warning? Usually on 2001+ models of Fords they have the seatbelt warning that won't stop until you fasten it. Just a thought.
Its an 00 its not the seatbelt... I think it might just be somthnig wrong with my computer thats why it keeps beeping. but i need to find a way to make it stop!!!
Sounds like the notorius "mystery beep" run amok! Sorry, don't know what the fix is.
Could it be your headlight setting??
Is your LS base, sport, premium?
What other options do you have? They might be on or off.
You might want to double-check the manual and see all the options you have....turn them all on then turn them all off. Then check if it beeps again. Other than that, I really don't know what to tell you. Good luck.
