LincolnSedan
Have rough idle most noticeable with foot on brakes, stopped. Mileage is 138k. The car displays no codes. A short while ago, within 20k miles, all cops (bought expensive aftermarket ones on amazon, not $23 pack one bay) and plugs where replaced, platinum either motorcraft or bosche, have to look. Paid careful attention, making sure they where grounded, checked the pre gaped gaps, have proper gaping. Idle did improve a noticablly after replacing cops and plugs. Used either dialectic greese or anti seize (only a bit on threads) to avoid corrosion for next service. This has a newer air filter. Recall spraying maf cleaner on maf a while ago but not very recently.
Asking for budget reasons due to expenses with multiple cars. The car has the original o2 sensors, no errors. Believe it has original egr. No knowledge of anything wrong with cats the car does not exibit any symptoms related to bad cats, loss of power gas mileage on hwy is 26.5 avg. Not aware of manifold vacuum leaks. The car has new valve cover gaskets which are installed perfectly. Timing is dead on, there are no known issues with slipped chains, chronic issues. Am trying to look at common, simple issues with no codes.
Considering o2 sensors, someone suggested
