Well, unfortunately, my LS is in the shop. Several things wrong:
1. Surging and jumpng in the transmission. Thought it just needed a PCM reflash, but it turns out it was the pressure control solenoid (this is what I was told at least by my father, service manager at the dealership)
2. Neither side mirror would adjust up. Needs a new switch.
3. Passenger seat heater would turn on, but sometimes turn right back off. Was a cracked heating element, being replaced.
4. Driver's door interior upper trim molding was loose, new clip needed.
5. Extreme road noise. From tire cupping. They rotated the tires, but still somewhat there supposedly, but got rid of vibration. Need a new set of tires, but not until I can afford it with some rims. Known problem with the stock tires for the 2004.
Also, they fixed the broken fog light and secured the front bumper front my run in with the raccoon a ways back. Luckily all of this was done under warranty. Still planning on getting an LSE kit once I can afford it.
