06LS Greek
Side View Mirror Glass Replacement Procedure:
501-09 Rear View Mirrors 2006 Lincoln LS
REMOVAL AND INSTALLATION Procedure revision date: 06/24/2005
View attachment LS Side View Mirror and Motor Replacement Procedure.doc
________________________________________
Exterior Mirror Glass
Removal and Installation
1. Push in the upper inboard area of the exterior mirror glass to access the mirror release tab.
2. NOTE: The mirror release tab is accessed from the lower out board corner.
Release the tab from the mirror motor, pull outward until the exterior mirror glass is released.
• If equipped, disconnect the heated mirror electrical connectors.
3. WARNING: Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage. Failure to follow this instruction may result in personal injury.
To install, reverse the removal procedure.
