man van windsheild wiper
topher5150
Grand Rapids, Michigan
So the man vans passenger side wiper got frozen to the glass I turned them on and now it only goes about half way up how do I fix it
This happened to my Cadillac one time. There was a plastic piece on top of where it hinges that popped up and a bolt that had come loose. All I had to do was make sure the wiper was in the down position and tighten it up and it worked fine from there on. I don't know if it will be the same for you, but it's worth a shot to check.
There can be only 1 man van...
on the f-150's the wiper post had ribs. If you striped them out you had to remove the nut, pull the arm, and put a small piece of tin foil on the post. No sure if you have the same setup or not.
