Is it bad to shift the car manually? Like up or down? Whats the difference between you doing it or the computer doing it? From what I hear going up(like 1st , second, drive) is ok but going down is not.(like from drive to second)
I've been manually shifting my 98
I've been manually shifting my 98 since I got it at 56k miles. Also rev to 7000 no problems. Even downshift it once in awhile. I change the Mobil 1 Mercon 5 ATF every 25-30k miles.
+1!!!Either you're just showing off or you like the ''bang'' - which in a pre-98 stock 4R70W will eventually grenade the one way clutch.
What's that you say? It's faster when you manually shift? Pfffft.![]()
You simply cannot consistently out shift the computer, period.![]()
like driller said, its NOT going to make the car faster.
the only reason i do it is when roll racing, so you dont have to wait for it to downshift.
