I have an '88 LSC, didn't know and tried to find out.
The shop manual has a couple ways to ID the rear end.
First there's a axle ID tag.
The ratio might be 3.08. But if it says 3L08, the "L" means it's got "Traction-Lok" .. a posi with 2 sets of clutches.
Same goes for the other gear ratios. (probably only available with the 2.73, 3:08 and 3.45, see chart below.)
The other way is the driver door sticker.
Along the bottom in the "AX" box, the ratio and type are coded.
I'll type this little chart out exactly as i see it, 'cause I may not actually understand it.
CODE CONVENTIONAL | RATIO
8 (M*)................................ 2.73:1
G ......................................2.26:1
Y (Z*) ...............................3.08:1
F (R*) ................................3.45:1
B .......................................2.47:1
* TRACTION-LOK
So, I guess if it's an M, Z, or R, the car has a posi... and none were available in the other ratios.
My car's door sticker has an E, so... what's up with that?
The Mark VII did not have the 3.45. It was 2.73, 3.08, or 3.23 with the trac-lok as an option. The diesel did have a 3.73, but that is the exception to the rule.
I picked up a 95 mustang gt rear end with the ax saying m. And the I.d tag had the L. It looked very identical to the rear end I had.
Yes good idea, I did get the struts because they wouldn't unbolt. I put the axles from the Lincoln and put them into the 8.8 and then the calipers went on perfect.
Where is cars and coffee? Sorry but I've never heard of that
I was still wondering why my door sticker axle code is E and searched for some clues and came up with one.
comments from a youtube video. " Mando's 1989 Lincoln LSC Mark 7 "
@goodride2004 From the factory all LSC models came with 3:27.1 and an open differential. Bill Blass models and other models came with 3:08.1 and open differentials. Any model could be ordered with the limited slip but it was a pay for extra and not standard.
@goodride2004 They came with 3:27.1 gears and an open differential. The limited slip was a pay for add on option and not standard. The way you can tell is look at the door sticker and axle code. E is limited slip and 5 is open.
So, what I gather is if a customer ordered the limited slip differential option with a new LSC, the door sticker AX code would be stamped "E".
But what about the 3:27 ratio.... ?
Here's my axle tag:
L 2 7 N 8 8 (8.8 ring) and then the date 7 H 31 (Y/M/D) meaning Aug. 31, 1987.
There's a bolt holding the tag's end, and then the tag numbers begin. The first letter I can make out is the L
Recall that "The ratio might be 3.08. But if it says 3L08, the "L" means it's got "Traction-Lok""
So, now I'm thinking there's a number 3 under the bolt head and I can't see it... So the "L27 is actually 3L27 .. or, 3.27:1 with the posi.
EDIT.. I have this PDF file from thelincolnmarkviiclub.org .. " [PDF] 1988 Lincoln Mark VII LSC Model Specifications . I think Oldschool turned me on to it a few years ago.
page 2
transmission - four speed automatic with overdrive gears
1st - 2.40:1
2nd - 1.47:1
3rd - 1.00:1
4th - 0.67:1
reverse - 2.00:1
transaxle - 3.27:1
and under optional equipment..
Traction-Lok Differential - $101.00
from my limited knowledge. all 87-92 LSC models came 3:27's, and BB models were 3:08's.
http://coffeeandcarshouston.com/
link provided to let you know its the first weekend of every month unless moved. all sorts of italian, german, and domestic ladies. summertime brings out the rarest vehicles. but the winter and spring shows are good also. check it when you have a chance, youll be impressed.![]()
