Mark VIII Differentials
pardon my ignorance, but if I were to brake-torque with an "open" diff, it would be only the right tire burning, right?
-thanks again for your input guys
not nessisarily.....
It depends most of the time as to which tire has the least load on it. You CAN get an open diff to spin both if your good enough. ;)
Mike
mrlandyacht said:
ok...so an open diff is kinda in between standard and posi...?
cool
no...an open differential is like what your thinking. You can still spin duals with an open diferential if the conditions are right for it.
just a posi alone is an awsome mod, then add 4.10s and a stall, you can drift around any corner and fishtail 100+feet
