mespock
Marxists - Socialists
Normally, you would insert the key in
the drivers door, turn left, then right
to disarm and reset it. If yours is malfunctioning,
you can disable it for good by doing the following:
Not sure if this has ever been posted but .... I found this today while searching for a solution to my son's Mark VIII.
The FACTORY ALARM DISARM WIRE IS
dk. green/purple |-|, located
in the drivers kick panel area or,
at the Ford Factory security module
located behind right side of dash,
near right kick panel.
Once located, splice into this wire with
a simular guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
However, at this point, this car would be exceedingly
easy to steel, so I suggest you get an aftermarket
alarm system to protect it from here on in.
