G
		grtVIII
Guest
Hi just changed my Wheel Hubs on My 98 Mark sounded like a Jet while I had the wheels off Inspected all the other bushings and ball joints.  Upper control arms were bad and wobbly  so I put it off til the next day on the way to get parts (about 30 miles driving) it sounded like a door creaking very loud was coming from under the car when I turned (not Lane switching) Right and left turns from a stop sign type turns. Picked up the new upper control arms replaced them (that was fun) it still makes the noise though somewhat quieter and only when I am making a right hand turn now. Rotated the tires checked air pressure pulled back off rotor caliper and such, put them back on
still makes the noise. Their is no shake in the wheel no crunching metal to metal when I go over pot holes and bumps all very quiet no jet sound driving on the highway but as soon as I make a stop / right hand turn I get the dreaded creak. as I said before I checked the LCA struts and other bushings they all look actually to be in very good condition no shimmy no shake no movement. The only thing that I see that I didnt like was the rotor before the hub change was stuck to the hub now there is movement in it but I would say that when the tire is tightened down that would eliminate that problem as the tire would sandwhich the rotor to the hub. I am at a complete loss for this. I have to put it back together each time to drive it to check for noises because it wont do it sitting still turning the wheel it has to be driving. Also I replaced the tabs on the drivers side wheel well cover (because I had to take it out to get the the UCA back bolt. I thought that might be rubbing in the turn and that wasnt it then I thought the shield was rubbing the rotor or the rim somehow in the turn but I dont see rub marks anywhere , not the tire not the rim not the wheel cover and not the dust shield for the rotor
please help Im at a loss.
