Mark VIII Stainless Steel Rear Shock Mounting Kit V2.0
DLF
Forked River
A complete bolt-on 304 Stainless Steel Rear Shock Mounting Kit.
Mounting Plates, with Energy Suspension Poly Bushings, 1/8" thick bushing washers, and the required 8mm hardware. Everything that you will need to install Thunderbird shocks in your Mark VIII.
The standard kit will have 3/8" (.375") ID bushings and washers for use with most domestic shock brands.
I can also supply the kits with 12mm (.472") ID bushings and washers for use with OEM Lincoln or Koni shocks.
If you need a different ID, please contact me.
Measure your shock shafts BEFORE you order!
If you do not specifically request the 12mm kit when you pay, then I will ship the 3/8" kit.
I will not sell this kit without the ES bushings and 1/8” washers as the bushings and washers supplied with replacement shocks will not fit through the hole in the body.
10 kits only, when they're gone, they're gone for good!
$65 shipped (lower 48)
Click HERE to Buy Now
now 5! lol
How fast can you get these out?
just had to replace the rear sway bar links..
Only 4 kits left, don't wait too long, I'm not going to do this again.
If I were to make another batch of these, the price would have to go up to $70 shipped.
Is there any interest at that price?
I'd buy a set if you made them again. $70 is fair.
I've still got clunking in the rear. The arnott shocks (with mounts) that I have now didn't even last 15k miles before the clunking noise showed up.
Ken
I've worked quite a bit on reducing the price of the components, and I'm happy to report that I'll be able to once again sell the complete kits for the original price of $65 shipped (lower 48)! :D
As the bushings and washers that come with shocks will not fit through the hole in the body, I'm not going to sell the bare plates, just the complete kits.
I'm ordering the parts today and should have the complete kits ready to ship by the end of the month.
In the mean time, I'm offering a pre-order sale price of only $60 shipped (lower 48). Once I've started shipping the price will revert to $65.
Click HERE to pre-order. Please also PM me with your desired size, either 3/8" or 12mm.
As Jay (98lincmk7lsc) is also interested in doing this, I've decided not to continue to produce these kits at this time.
