DLF
If you want a completely bolt-on solution that will allow you you use any MN-12 Thunderbird rear springs, this is it. A full set of both upper and lower UHMW spring perches as pictured. The included hardware to retain the upper perches is stainless steel.
UHMW is an extremely durable and light weight material, and each perch weighs less than 1 lb.
They are designed to use Prothane 6-1709 spring isolators, and you'll need two sets.
Comments from a satisfied user HERE and HERE.
Currently available only in white, shipped two days after payment is received.
I know that these are expensive, but they represent $40+ in materials and almost two days labor.
An elegant solution, for those that want the best.
$300 shipped (lower 48)
