Mark VIII
windcloudrdr
Moulton
I just became a member of your web site . I talked to a member named Danial yesterday in Huntsville Al. An he said if I had problems I could get Ans on here, so here I am. I Own a 1996 Mark VIII since New about 110,ooo miles has been a good car up to now . The Problem I have is with the Fuel pump an Air Cond. won't come on.I have taken it to a shop an thay told me the Varable Load Control Module is bad it's mounted in front of the rad. an above the Trans Oil cooler behind the Grill. I was able to get the Fuel pump to work by grounding the wire that goes into the control Module But still no Air conditioner, I grounded this wire an left the box out an grounded the wire an the car ran just like it did with the module in so not sure what this box does. OK so then I found a used module in a wrecking yard it worked it that car, so instaled it in mine, the same problem. So now I not sure if that module is the problem. If any one has had this problem maybe thay can shed some light on it. I guess I need a wireing Digram, or a good Mech ha ha. Any help would be Appricated. I sure I will enjoy this forum. Thanks Jerome (Windcloud)
LVC Recruiting!!!
See, I have been doing some LVC recruiting! This guy has a nice 96 that he has had since new! I told him to try to find some info here. I don't know if he has gotten it fixed yet or not though! But, thanks for making me look good by giving him some info guys! LVC is the SHIZZZIITTTTT!!!
How about you recruit people who aren't lazy or afraid of the search function, hmmmm? Damn you, infidel!
:D
Damn Frogman, Those are harsh words! lol How could I know of his search function using capabilities? Where do I get the search function using capabilitie recognizing capabilitie?
Never mind, I guess that would just be called coaching my recruits! Right? But I am not a Veteran of the site so I am only a "Recruiter", You and your professional sarcasm abilities qualify more for the coaching position! lol
